slepr1
- 3:17 AM
- Jul 19, 2014
- Stoney Creek, Ontario
After installing engine & rebuilt 727 trans I notice there was no spring attached to the gearshift control lever, to keep the lever closed when no throttle. The lever normal resting position was not at full closed. I am using a Lokar throttle and kickdown setup. We installed a spring from the gearshift lever toward the carb to keep it closed.
Now the gas pedal is pretty hard to push. Probably too heavy of a spring? What spring is suppose to be used? I see in past posts that some pics have the spring and some do not.
