63 fury 440 motor mounts
63fury500
11:05 PM
Beaver Dam, Wisconsin 53916
Looking for a source to buy a complete set of motor mounts to put a 440 into a 63 fury,the fury had a 361 so its got the big block kmember,any pics and info on where to get mounts ,thanx in advance
Well Schumacher is out of stock and I doubt they will be anytime soon.You might try Mancini or Bob Mazzolini as they might have some in stock. Trans Dapt don't make them for B bodies.You may want to look for used Big Block engine brackets(you don't have the ones from the 361 ?) the insulators are readily available most places.
So I looked up Bob Mazzolini and their store says the have 'um #SKU 81476. I would call to be sure.
Yeah, I also need a set
For the 63 Polara
I have spoken with Schumacher and the reason is the Subcontractor has a tooling issue (?)
Bob Mazolinni is only 110 miles down the street from me...He's the guy I bought my 1970 Hemi from
Thanks for this post Darter6
Call Joe Souchy
There isn't a BB K frame. It's a V-8 K frame. If you have mounting brackets from the 361 they will work on the 440. Just need the insulators if you don't have those from the 361. Also those aren't BB, just V-8.
As stated call Joe Suchy.
FYI, Buy the one that interlock or use a torque strap ! I ripped mounts left & right when I was playing around ! Well always Left mount ! haha. Enjoy!
There is a guy who re-pops the brackets and the inserts can be bought any part store.
Schumacher Poly Locks are good mounts. The biscuit style mount is famous for coming apart. Mainly the left one and especially with a 4-spd.
Yeah, Mike is having issues with the manufacturer not making the parts.
Thanx everyone,Ill call joe and also check
thanx
I found two sets of NOS on ebay. They're your best bet for longevity, made in usa.
Here's the brackets off my '62 361, installed on my 440. Don't mix them up. (2228 driver's side)
2227 passenger side
If you still have the 361? The brackets and insulators will work on the 440! The insulators are available at NAPA Inexpensive too!
The 62 Dart I picked up is a slant car, and I figured Schmaker made a conversion brackets for it but guess not! And he is out of almost everything anyway! Looks like a hunt for a v8 k and do the swap. It is getting hard on this woreout 71 years geezer to do such, especially in 110 degree SW Texas! !!!
