6 pak intake question
davek
12:37 PM
columbia SC
I have a 1970 cast intake and an aftermarket edlebrock intake. I noticed the edlebrock is a 1/2 taller,will this be a problem with my ramcharger hood? thanks 1970 Bee 440
also could someone post a pic were the coil mounts to. Cant find a good pic.
Is it taller when sitting on the engine, or taller from the bottom of the heat crossover when sitting on the bench?
Do you think you are the first guy to run an aftermarket 6bbl intake with an air grabber hood?
The coil mounts on a bracket that uses the two intake bolts on the right rear of the intake.
They are both cast. I assume you're referring to a cast iron unit verses an aluminum unit. Should be the same height
