WesleyK
68 a833 4spd: ok so I’m putting a new gasket between the case and the tail housing. I’ve followed Passons manual to a T and all keys and gears seem the be lining up good and seating till there’s about not quite 1/8” before the housings touch and it won’t go any more. I installed the main shaft with the 1-2 and 3-4 slider locked in gear. When it seats they go to neutral position. I can rotate the input shaft when the sliders are in neutral. But then try to slide them back into gear and I can’t do that either. I done this over 7 or 8 times with the same result every time. And also all 16 of my roller bearings are seated and accounted for each time as well. So what am I missing guys?
