Trunk seal
greenmachine
5:51 AM
portland
Got this done last night. Took my time, came out nice.
I have the trunk seal from soff seal. Installed as described. Trunk lid was aligned before and latch/locker adjusted to pull down the lid.
But I can see from the sides when I look over the rear that the seal pushes the trunk lid in the mid section along the quarter a few mm up.
Is that normal and will the seal sit after a while?
El. Padrino, on my 66 Satellite we had the same issue, flush at the hinge, latch and above flush in the center of the sides. It did improve some as the seal sat with the trunk closed but still was high in the center. We ended-up adjusting the trunk so it was under flush at the hinge and the latch and the center was flush. After sitting with the deck lid closed for a couple of weeks we readjusted the lid and it sets very close everywhere. Brian.
Good point, thanks! I am tired of loosen the bolts again and start aligning again again and again but..yeah, do it :(
