Dynamat or Other Sound Dampening Question
I was thinking about using dynamat or something like it . One of my main concerns was if wasn't glue down good and had voids in it , it would rust from moisture getting to it and how could you tell and less you see a hole coming through the metal . Wondering if anybody has taken there dynamat off after bunch a years and seen what shape there floors or whatever they had cover ? I 'm thinking about using Lizard skin for heat and sound .
How would moisture get under the mat to cause the rust?
Heater core leak ,window seals leak ,
condensation , Let of places might not be seal tight , around floor shifter , roll cage , seat belt mountings , dimmer switch , etc.
I guess if the install was done incorrectly or shoddy, then yes you are correct. The sticky mats are pretty thick and have a durable foil sheet on top. Once its down it doesn't go anywhere and conforms to everything.
i used Cool-It Thermotec off Summit Racing. a few large boxes did the 66. also did the trunk was having so much fun. then used some heat liner on top also was Thermotec
watermelon
23E2F274-EE0F-45FC-A0B8-C649AFC9EA66.jpeg 8241BB3F-51AC-459E-AD31-B41021EEB2B5.jpeg
