- 3:12 AM
- Dec 4, 2009
- Pasadena, Texas
Oh man, that was funny! You do plan on sticking around here, right!?Nothing runs like a mopar. Well....maybe OJ Simpson I guess.
Yeah...ill be around. Lots of stuff to click on.Oh man, that was funny! You do plan on sticking around here, right!?![]()
Just as long as you're using a scoop....or notYeah...ill be around. Lots of stuff to click on.
It's not too hard to make a stock stroke 383 run pretty good and the same goes for a 400. Yes, the 400 was considered a smog motor with it's low compression but who these days is still running a stock 400? I know there are some out there but not many. 400's used to be cheap just because of that and most of them have cast cranks but Mom's cast cranks are much better than the GM cast cranks and don't fail like the GM stuff. A 383 forged crank will bolt into a 400 but yeah, needs to be rebalanced. I'll take a big bore short stroke engine with mayo any day!Too many think a 400 is worthless unless you stroke it.....and that's not true.
Thanks Wild. I like the idea of the 470. Should be enough room for a half inch pickup. 4.25 stroke might get a little tight and require an external oil system. Good info on the true of the cranks. I've got a lot reading to do.
I like the 470 too...and am helping someone with that build now. Thing is, a stock stroke 400 will act very well with the right stuff in it and without slinging a big.....well, you knowI like the 470 allot, and since it uses a 2.20 rod journal there's lots of room...
But the 512 also uses the 2.20 for journal & an internal pickup fits fine...
FWIW current thinking is the 1/2" pickup cause more problems than it solves..
Yeah...a 2.20 is a standard chebby spec journal. That would help for clearance issues. With the 4.25 the 3/8 pickup will do just fine. Hemi use a 1/2 pickup. More oil on the twist. More rpm. More oil. I spin my junk to 6800. 1/2 pickup.I like the 470 allot, and since it uses a 2.20 rod journal there's lots of room...
Agree. Rotating mass isn't always your friend.I like the 470 too...and am helping someone with that build now. Thing is, a stock stroke 400 will act very well with the right stuff in it and without slinging a big.....well, you know![]()
Thing is most of the stroker bob weights are significantly lower that the standard stroke bob weights... On my 440/512 the piston & rod assy is over a pound lighter that the original parts... At one time 440 Source was also offering gun drilled lightweight cranks...Agree. Rotating mass isn't always your friend.
I personally have no idea but there are plenty of them out there running well into the 9's & some are in the 8's...Price is up there....plus, what kind of twist do they have.....?
They push it for the 4.25 because of the inertia of the rotating mass. Its a hefty assembly. Ok for a street motor, but a race application that sees over 6000 rpm, balance is everything. Brand new factory motors balance around 28 grams or more and run smooth. You'd never know. High end crates around 16 grams. NASCAR 4 grams and under. That's why they stay together at 8000. Tales a lot of work to make all that weight work in harmony. Lots of technicals umm hmm.Actually they still do... But only for the 4.25 stroke... An additional 6.5 lbs off the rotating assy... For a $150 fee..
http://store.440source.com/Ultralight-Crankshaft/productinfo/44042506800-6-LW/
Correction, not gun drilled, but lightened
Bob weight for the crankshaft must be balanced with the bobweight of the piston, rod and rings. The number they show is for the overall assembly i believe. Lots of technicals. Have to remove weight from crankshaft to balance with others. The difference between is what matters. Like within 4 grams of each other for Nascar.Have you found this chart yet?
