400 block motor mount compatability
Thanks Wild. I like the idea of the 470. Should be enough room for a half inch pickup. 4.25 stroke might get a little tight and require an external oil system. Good info on the true of the cranks. I've got a lot reading to do.
Mine is a 400 stroked to 470
The 77 400 I pulled from a van ran like a scalded dog in my 70 Super Bee.
To the OP-
Make sure your balance is correct with respect to the crank and the trans converter.
I did not the first time and ended up with a vibration that started at 60 MPH and didn't go away until 120!
To the OP-
Thanks very much. The people here are great. Lots of knowledge being shared. Real cool. I run a 4 speed with a 4.56 rear gear and about 29 inch rear tire.
might want to check into flywheel balance as well, then.
