just my 2 cents .
You need about 2-3 mph , that is extra HP needed .
Your 130 should give you a lot better ET . BUT ET is chassis , so i would be looking at confirming your chassis is up to scratch . My standard CNC port stealths 11:1 505ci , 272/272 sft cam @ 3690 went 10.50 with a 4150 type carb . With TF 270 heads went 10.25 @ 129.65 . Foot braking .Had my own prepped 1050 by this stage
New World block same cam etc @ 90 lbs heavier has gone 10.27@130.8 leaving @ 4200 on the brake , goes 1.42 - 1.44
The 5100 stall vert is ok , I ran a 9" 5000 now 8"6000
oh yeah I have the Mopar 5 blade clutch fan and am running full exhaust to diff , 4.1 gears and 30"radials
Tex
