- 8:24 AM
- Mar 10, 2010
- Hanover, Pennslyvania
This is what I never understood about parasitic loss through the drivetrain...Lets assume you start with an engine setup that makes 400hp at the flywheel and assuming 20% drive train loss, you should expect to see 333hp at the wheels. A 67hp loss. Now, you start to mod the motor and when you are done, you are making 550hp at the flywheel. Still assuming the 20% loss, you are now making 458hp at the wheels. a loss of 93hp. Since no other changes were made to the drive train, the power loss should have remained constant at 67hp. Parasitic loss of hp through a torqueflite with a specific torque converter and dana 60 with a given set of gears should be constant regardless of the hp the engine is making. Correct?
Hmmm. So the more power you make the more you lose because of more friction and more acceleration? The faster a guy goes the more power he loses because of greater forces of resistance? Makes sense kinda.The dyno is measuring both friction times acceleration, and mass times acceleration losses.
If torque was measured at a constant speed, the losses would be mostly just frictional losses, but under acceleration all the losses are multiplied by rate of change (acceleration)
I have an engine/trans combo up for sale that I guarantee will make 500+ at the wheels.
I would have, but didn’t have to it sold already.So are you going to PROVE IT on an Engine Dyno before any Money exchanges hands ?
we get it already get over yourself. you have an engine dyno at your disposal and dyno all your customers engines and I’m sure they’re happy. If you have a trusted builder and or combo a dyno isn’t needed IMO.
