8-3/4 question
zigs
10:22 PM
Yakima Washington
Were
all B-body 8-3/4 axles adjustable. if not what years were.
So by my picture can you tell if this is pre 65 or not? Its out of a Belvedere. Previous owner said it belonged to his dad but didn't know what year , must have been detached from the car when he got it.
There is only one adjuster on the passenger side. That side adjusts both sides.
Also the earlier 8.75 had a nut on the axle. The newer style has axles with no nut.
Your adjuster setup is 65 and newer and like BeepBeepRR stated the pre 65 setup used a nut on the outside of the axle and I believe you had to use shims on the pre 65 setup to adjust the end play instead of the newer setup like you have.
1964 and earlier would have had what is called a tapered axle. As I said before it would have a nut and a hub assembly.
65 and later would have Axles that slide in.
I believe it's to adjust the side to side shaft play,(lash)? There is a specified amount of allowable movement. I think it gets adjusted with feeler gauges. Not sure how much is recommended by Chrysler. It's been over 40 years for me. Good luck!:)
The 1966 Factory service manual states .013 to.023 for the axle shaft end play. Usually a dial indicator is used to set the clearance. Most just go by feel.
Also doesn't matter which stud the adjuster lock is. Set your axle end play and put the adjuster on the stud where it fits best.
Is it just me, or do those flange nuts look like they're not getting much engagement on the studs?
Also doesn't matter which stud the adjuster lock is. Set your backlash and put the adjuster on the stud where it fits best.
I always found the adjuster lock positioned at 2:00 stud and held down with that washer head nut shown in #1 post on the 2:00 stud.
Yes, those adjuster nuts are not drawn down enough on the studs.
I had already backed nuts off , thought I'd better ask the question before I got too far along.
Dial indicator is best; after you set it and try the end play, you’ll feel it move but not really see movement(if that makes sense).
It's also a good idea to whack the axle ends during adjustment checks to make sure everything is seated before you button it up.I use a Snap-on deadblow plastic faced 2 lb hammer.Don't beat the hell out of it.
