Bought though ebay. Don't if they have a supply of them. Think Ford C6 is the same but not postive.Well now that Fran posted the part number I won't have to remove the tail housing.![]()
Ran a driveshaft that was to short, a screw up.I've been rebuilding TFs for close to 50 years now and never needed to replace the extension housing bushing in the car. If it wasn't bad on the bench it will out last the trans rebuild and can be done the next time. Don't put the drive shaft yoke in dry (like some other things)!
Here's a better deal than mine, check details say 727 but check. not mine.https://www.ebay.com/i/254104262633...MI_K7ytdik5QIVlIzICh1qeQuSEAQYAiABEgLpQPD_BwEBought though ebay. Don't if they have a supply of them. Think Ford C6 is the same but not postive.
Why you, I oughta....With jack stands; just couldn’t help it Ed!
Gotta make sure the oil hole is in the proper position when you drive the new one in, too.Well now that Fran posted the part number I won't have to remove the tail housing.![]()
Thanks to fellow member @Beekeeper , I can attest the Miller tool is amazingly easy to use and works like a champ.Here's a better deal than mine, check details say 727 but check. not mine.https://www.ebay.com/i/254104262633...MI_K7ytdik5QIVlIzICh1qeQuSEAQYAiABEgLpQPD_BwE
