Thanks, I’m plugging away, hoping to install the exhaust the weekend. It takes times as I have too many other projects on the go and I’m doing all this restoration myselfWow, you are making a lot of progress! Keep up the good work!
I hear ya, without paying a crazy high price I could not find an oem 26 inch core anywhere close by. An aluminum rad with the car, but that’s not the look I wanted. I have it mounted now and it fits and looks nice.Well that sucks... why I love OE radiators, they fit and cool just fine.
Some more progress, radio is rebuilt with FM and aux port, speaker is fitted, close by it clears. getting ready for the dash installStill plugging away in between other projects and jobs. First time the car has been outside on her own wheels, started to mock up the AC
View attachment 855432 View attachment 855433 View attachment 855434 View attachment 855435 View attachment 855436 View attachment 855437 View attachment 855438
What power wire did you use to power up your classic auto air? The original Heater wire?Nice! I really enjoy my upgraded radio. It looks stock but I enjoy the ability to listen to my own music through a system that is vastly superior to the original.
Hawk
Thank you very much, thanks for your inputVery briefly, I split my system into two power sources that travel through the bulkhead connector. The classic auto air is powered by the new, second power source.
I converted my ammeter gauge into a voltmeter. I put a 70 amp alternator on my system and upgraded those wires. The normal fusible link and wire continues to exist that powers all the stock power needs and my radio. The wire that went from under the dash to the alternator was now no longer needed. That became a second fusible link to power my classic auto air and fuel pump.
Note that I originally I DID use the stock A/C fuse and wire to power the system. It is a 20 amp so it should be able to handle it. However, I think I have a bit of a poor connection here, and the fuse failed once and later when I felt it is was hot. This scared me so that made me decide to move it to the other fuse block I installed under the dash.
Bottom line is I think you SHOULD be able to use the A/C power (if memory serves it is the last fuse on the left side) - maybe my situation was just due to a poor connection. But if you do, monitor that connector very carefully!!!
Let me know if you need greater details and good luck!
Hawk
