Usnguenther23
Alright guys tried many different connections and can’t figure it out. I am burning the blue wire from the alternator to the alt regulator everytime I connect the battery. The colors are a little mixed up but here’s my lay out right now with a few pics and color coded diagram that doesn’t full match my colors due to knee harness.
pink wire (blue/yellow in diagram) from ignition switch goes to ignition resistor with blue wire from alternator reg and wire from alternator.
green wire is alt reg to alternator
other side of ignition resistor is brown wire from coil and pink wire (brown in diagram) from ignition switch.
it could be as simple as wrong gauge wire however it’s the same size on the stock alternator regulator so I’m doubting it.
here’s some pics thanks for the help again guys
