Fender Tag Decode: Halp!
Mazzif
2:00 AM
USA
Trying to figure my fender tag...but it has some maybe conflicting information. I beleive this to be a BB400 with 2bbl carb. Fender tag says BB400 and 383? Its the E63 code tripping me out. Here was my best guessView attachment 862170 View attachment 862170
WH23:
Dodge Coronet,Charger
High
2 Door Hardtop
M3G: 400 175HP(net) OR 185HP(net) 1-2BBL 8 CYL
1973
St. Louis, MO, USA
133466: Sequence number
E63: 383 cid 4 barrel V8 H.P. 335hp
D34: Light Duty Automatic Transmission
FY1: Top Banana Exterior Color
H6X9: Trim - High, Vinyl Bucket Seats, Black
TX9: Black Diamond Int. Door Frames
A27: Build Date: October 27
106825: Order number
V4X: Unknown Top Color
U: USA Specifications
B41: Front Disc Brakes w/Standard 10in RR Drum
C16: Console w/Woodgrain Panel
C56: Bucket Seats
G11: Tinted Glass (all)
G35: Delete Standard Outside Mirror
H51: Air Conditioning with Heater
J25: 3 Speed Wipers
J52: Inside Hood Release
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
M25: Wide sill moldings
H26: Unknown
H31: Rear Window Defogger
H95: Unknown
P31: Power Windows
R21: AM/FM Radio (5 1/2 Watts)
V5X: Body Side Stripes, Black
28: Unknown
END: End of Sales Codes
In 1973 E63 is the code for a 400 2 bbl. Up to 71 or so, it was also the code for the 383's. So, as the year is 1973, you have a 400; 383's ended around '71 Not sure what you were using to decode, links do not work.
My best guess
V4x- is canopy vinal top/ black
The H codes are Ms
M26- wheel moldings
M-31 belt and hood molding
M-95. Assist handles
28- 28” radiator
Agreed. Last year for the 383 was 71. It looks like they carried the E63 code over to the 400, which was the the replacement for the 383.
WH23:
High
2 Door Hardtop
1973
St. Louis, MO, USA
E63: 400-2 Barrel 72-76
D34: TorqueFlite Automatic Transmission
TX9: Upper Door Frame: Black
A27: Build Date: October 27, 72
V4X: Black Canopy Vinyl Roof
C56: Bucket Seats
J25: 3 Speed Wipers
M26: Wheel Lip Molding
M31: Belt & Hood Molding
M95: Assist Handles
P31: Power Windows
28: 28" Radiator
The code E63 changed to 400 2bbl in 1971. In 1971 E65 was the code for 383 4bbl. I can't say this is true in all cases, but I have seen the E65 code in 71,with my own little peepers.
Thanks for all the information guys. You rock!
