Can the pistons be removed through the bottom of a 440?
Trench
11:08 AM
nova scotia
Hi all, I was just reading a rebuild book and it was saying to remove the pistons through the bottom of the motor to avoid using a reamer. Can this be done with the 440?
The answer is NO... The main bearing webbing will interfere... Last engine I saw the pistons come out the bottom of was a 230 inline six...
They can indeed! Get a sledgehammer and get to it, lol!
This!
I made that mistake recently when I was tapping a piston down to see if it was seized in the bore. It went down pretty smoothly after some PB Blaster...then popped out the bottom and I had an "Awwww.....FUUUUUDGE!" moment. lol
Why would you want to. The ridge represents wear in the cylinder and you should then use a micrometer to see if boring is needed. Just my opinion.
Sure you can, Its easy.
So I found where I read it. It's HOW TO REBUILD THE BIG BLOCK MOPAR by Arvid Svendsen.
