Dreamcatcher
Will fish for food
Good point but I worked in Prudhoe Bay Alaska for 30years. We used DELO 0-30oil in all big rigs and pickups. Never an issue.
We had block heaters some of the larger cat engines had pan heaters but most didn't. The only issue I remember fired a big cat engine one night at -47F and it blew the oil filter off. After that the big engines had pan heaters. Of coarse the big V-16 Cummins we had on the pumping units had pre-heaters. But they were 2000 hydraulic HP units.Do you use preheaters or block heaters to keep the coolant and oil warm. Delo has been a proven oil in the big rigs. Many oils are good for me it's amsoil. The product has let my big rigs go for over a million miles without a teardown.
nope....Anyone hear of Ligui Moly Synthetic oil ?
Fram being a big name brand was counterfeited a lot but don't know if that's still going on or not. One way to find out if you have a cheap, good or excellent filter is to cut them open and look how they are made. That is also available on the internet for freeI guess if it is a which oil do you use thread I like Rotella 15-40 in 2500 ram diesel 168000 strong and in our work horse 3500 ram dully diesel. 250000 and counting and never used with out towing a big load. Mobile 5000 in the cars. And to really get this into a street fight LOL Fram filters in every thing for the past 46 years...Hahhah....
I change oil more often than most as well. 3000 to 3500 miles and we live out in the hills so most everything can be considered highway miles.Fram being a big name brand was counterfeited a lot but don't know if that's still going on or not. One way to find out if you have a cheap, good or excellent filter is to cut them open and look how they are made. That is also available on the internet for free![]()
Running flat tappets I'm useing zddp. I used the Penn Grade break in oil then after 500 miles went to their 10w 30w partial synthetic.
Keep the zddp as syn blend contains 5% or less syn oil. It's nearly as expensive as full syn so I see it as a rip
The Mobil 1 has a ZDDP level of 1000 ppm
All flat tappet cams need either a zinc oil, or at least a zinc additive. Your last sentence shows how little of a grasp on how important zinc is in a flat tappet cam engine.
Zinc....a multi million dollar industry. Are we being had?
Do they have lifters and push rods in those?For the 20 years I was in the Army fixing helicopters all we ever used was synthetic. That's going back over 30 years now when I started. Need that dependibility. Can park on a cloud when you crap an engine or gearbox.
