repsol17
- 12:21 PM
- Apr 29, 2015
- Ft Lauderdale Florida
Been searching thru many previous threads and searching over the web with no real such luck. I've learned a lot but not enough unfortunately.
My passenger side headlight is close to hitting the top outer edge in the radius area when the light is closing (see pic).
With the grille removed, it appears that there's a round plate with 3 screws in which the pivoting shaft goes thru. I also noticed what might be a white bushing possibly around the shaft as well.
Is this round plate (with screws) the culprit that allows for adjustment ? and is there another plate on the other side too..which seems impossible to get to if there is.
I did loosen up the 3 screws pretty much and I couldn't budge the fixture. So before I created an "OOPS..SH$T" I stopped.
Can anyone explain what's need to be done ? Is there a rebuild kit of sort too ?
Thanks again
Thanks again
