lochenjons
1970 Charger with 383. Wiring is in OK shape but never given me this issue before. Only thing I did differently before this issue popped up was drove over some rough roads and surfaces.
Got it home and went to start it a little later and the key went to start and voltmeter dropped to 0 but absolutely no noise from starter and smoke started coming from the connector below:
Left it alone and then the next day went to crank it and it cranked slower than normal for a couple seconds, cranked it again and then the same issue happened. No noise or anything from starter and a smoking connector.
Any of you guys deal with this before?
This weekend if it doesn't rain I'm going to pull those connectors and check their cleanliness, then start checking voltage at starter etc, check ground and make sure everything is okay. Just wanted to get a jump start on what to check for if anyone has experienced anything like this before. Thanks !
