FOR SALE Hemi low deck 400 cast block
blown away
3:29 AM
neche
for sale low deck cast iron 400 block that uses 426 hemi heads that Charlie malyuke made fr his dodge colt pro stock and John hagen, wally dyck bought this block and set records with it in a FED. Selling block fr $1600. Plus ride thx
Judging by the water pump housing, looks like hard fill is in it, if so, how much?
How much hard filled? Or block price? 1600. Plus ride. Half hard filled!
Ok, half filled. Thanks!
View attachment 871531 View attachment 871535 View attachment 871536 View attachment 871537 View attachment 871538 View attachment 871539 View attachment 871540 for sale low deck cast iron 400 block that uses 426 hemi heads that Charlie malyuke made fr his dodge colt pro stock and John hagen, wally dyck bought this block and set records with it in a FED. Selling block fr $1600. Plus ride thx
Any issues with it ? Doesn't look half filled in the freeze plug holes , maybe just around the top of the block where the interior head bolt bosses were added . Any cracks around them ? Hard to tell dirty as it is .
Do standard hemi heads fit it ?
How much overbore ?
Where would it be shipped from ?
they way the pan rail is
ground out was for return oil faster,that block is very close to this low deck hemi
How much overbore ?
Yes std hemi heads fit. It can be shipped frm from neche North Dakota thx
not sure about the combination they used,they could of used a 426 or 440 crank,or low deck crank,i did have a race motor they open up the mains for rb crank instead of cutting down a rb crank to low deck mains
No info yet ?
might be a 383 like this pic,is there casting numbers on the side and date,i know the motor mount ears was milled off,but i do that to all of mine
Look at the fourth pic a little closer. You can see the casting numbers. 400 block casting 230. Also look at the size of the main webbing dead give away.
