gkent
I can't make out diddly squat from those pics. There's nothing to reference to.
https://www.forbbodiesonly.com/moparforum/threads/69-gtx.51515/page-9#post-910121814
Start here, after doing it I could have done a little better the second time but you'll get an idea. I tried to simulate suspension in a compressed state (big bump with weight) and then went another 1-2 inches for the height in the tub. Really not that hard just time consuming and cramped working space.
Sorry, it's hard to stick your head in there and take a picture. If you look at yours and then the pictures I'm sure you can figure it out.I can't make out diddly squat from those pics. There's nothing to reference to.
I was planning on using Eastwood's Seam Sealer.General question does anyone use any kind of seam sealer with the tub installation.
Looks good BigFoot. By the way, through U.S. Car Tools Facebook page, I contacted them about the proper installation of their body stiffening kit and Win Cooke shot me back some detailed pictures that really helped me out. I just wanted to give him a big vote of thanks and let the group know that he is more than willing to let us home builders out. It's been snowing pretty good here and I've been working to remove the undercoating so I can weld on the front tower supports now that I know how to install them. I purchased a cheap Harbor Freight needle scaler and it seems to work pretty well though I do need ear plugs and a mask. With my Parkinson's I can only go so long before I need to take a break but I try to work on it some each day. Wish me luck.We are going to de hump as well. Im using Caltracs and split monos. my wheel is forward and the 295/65r 15s now hit front of wheel opening. How did you guys move it back?
I ordered right leaf springs For the US car tool relocation kit. We’re doing new Quarters. Hoping to use Hoosier 29.5 11.5 15 on 15x12
View attachment 875354 View attachment 875355
On the relocation some people are drilling another set of wholes because of the s s springs. I believe someone shows the relocation done in the suspension & brake post.We are going to de hump as well. Im using Caltracs and split monos. my wheel is forward and the 295/65r 15s now hit front of wheel opening. How did you guys move it back?
Also watch your shocks towers as you move it back the shock towers above will become center over the rear axle just some fyi.We are going to de hump as well. Im using Caltracs and split monos. my wheel is forward and the 295/65r 15s now hit front of wheel opening. How did you guys move it back?
Big foot what are you using for rear hangers for caltracs.We are going to de hump as well. Im using Caltracs and split monos. my wheel is forward and the 295/65r 15s now hit front of wheel opening. How did you guys move it back?
I used the same Caltrac/mono set up on my charger but with 30x11.7 (315-60r-15s) on 15x9 wheels, which all made the rear sit to hi. So I got some of these lowering blocks, which nicely adjust front to back.... Also, I misspoke earlier, I did the spring offset kit/mod which is all mine needed for tire clearance, not the relocate.We are going to de hump as well. Im using Caltracs and split monos. my wheel is forward and the 295/65r 15s now hit front of wheel opening. How did you guys move it back?
Your Charger has a killer stance!!! Absolute beautiful car!I used the same Caltrac/mono set up on my charger but with 30x11.7 (305-60r-15s) on 15x9 wheels, which all made the rear sit to hi, So I got some of these lowering blocks, which adjust front to back.... Also, I misspoke earlier, I did the offset kit/mod not the relocate...
On the front mounts folks are redrilling one inch back. You can also for the rears only a thought but you could put sliders on the rear. We're is shock tower compared to rear housing.calvert sent me the wrong rear shackles for an A body according to part numbers. Bought them about a year ago and just noticed when installing. The rear hanger location is a bit far back. Going to make new shackles and move mounting point forward. (First pic where it’s at now) Thought about re drilling new holes on the US Car tool front frame rail brackets. (currently using center hole)
View attachment 875512 View attachment 875513 View attachment 875516
