Valve cover grommet source?
Dennis H
12:10 AM
San Jose
Shop can’t source the large grommet. Got the POV one. Where can these fittings be found. Reported to be 1970 vintage.
Mancini Racing, was the last place I got mine
I don't use factory vc's anymore,
but the ones from my org. vc's
worked in the cast MP cast alum vc's for PCV too
had to put a little lube on the grommet to install it
they fit tight, the fill/breather holes are twist type caps
MegaPartsUSA.com has them I'm sure too
I found mine at Autozone. Dorman
I bought one at NAPA in the past.
Off topic, shop says they are warped. I laid them on the floor and they seems pretty straight, nothing torquing them down a bit wouldn’t cure. Any opinions?
If any of the bolt holes is dented in I lay the VC edge across the jaws of my bench vise and tap them back to flat with a small hammer.
You'd want them to be as plumb/true as can be before you approach the head with 'em, Dennis.
I've had luck using my gunsmith type small brass hammer (one end is plastic, the other brass)
and holding them against the bench vise, then laying a straight edge on them to eyeball.
OEM Original at your local Dodge dealer...
PVC: 3751510
Breather: 2946079
Megaparts. Now I can make an add without using a thimble.
