I am planning out a new driveshaft for a few reasons:
The one I have must have been for a B body with an 8 3/4 rear axle because I had a vibration in it when I got the Roadrunner, and I learned that many B bodies with the
Dana 60 over the years may have had the driveshaft swapped out, and while the driveshaft "fits" from a 8 3/4 B body, it's a little too long and that often leads to a vibration, along with other possible problems. Sure enough, I measured it and BINGO, it was the standard length of the 8 3/4 shaft.
When I had a well known, reputable local driveshaft shop I've done business with a few times take it to cut and rebalance, his comments about the condition were "less than stellar"...
Since I am replacing/installing so much in about 2 weeks, including the entire front suspension, leaf springs, Assassin traction bars, sliders, spring perches, and 4 wheel disc brakes, and all of the rear suspension parts are part of the QUEST for much better traction, and I will be using my line lock for the first time, and if I can I'll get the Hydramax hydraulic throwout bearing installed along with the HitMaster launch control system, well it just makes sense to get a driveshaft now.
I have to make clear, the driveshaft I'm getting is also expected to handle my future stroker motor's output, and I spoke with the Bill Mitchell World block (aluminum) vendor today, and confirmed that I would be ready to pay for the block in full by late May early June.
So YES, unless something bad happens, I will OWN an aluminum 4.49 bore block.
Then I will discuss the details with their shop engineers, and see what comes of that. I'll know if that Weiand 6bbl intake fits under my hood soon as it arrives this week
If it fits, I would like to use it for the stroker build, using my Promax modded Holley carbs to start out.
Later, if I can, I may go this route w/the Weiand:
