Need some help identifying what this hood is
Wizard
9:14 PM
Dillsburg, PA
Someone said its off a 73 wagon but I don't think it is. I looked that car up and did not have the same hood. If you notice it does say Plymouth down on the bottom right side of hood. The date of the picture taken covers it up but its there in chrome letters. Any ideas what year model this belongs to?
thnks,
Wizard
that crossed my mind as well but it looked a little too long , but maybe the pics are deceiving
thnks,
Wizard
View attachment 902078 View attachment 902079 View attachment 902080
Looks like a 71+ B-Body, Sort of looks like the regular flat '71 Charger hood, but may have been used on Coronets of the same vintage?
Maybe 72 can't remember how the grilles work every year was different but definitely a charger hood
Not an Easy body....and if it was for 72 through 74 E, it would also fit a 70 to 71
I looked at my '73 Charger and it is close, but not quite. The front of the '73 Charger is more pointed.
Guys, its not a dodge. It has Plymouth script in chrome on bottom right hand corner. You can hardly see it due to the date of the picture taken is covering it. Just weird that it is directly on top of it. Should just take another pic of it and post it. Anyways pretty sure its the 72-74 barracuda hood. I looked at other ones with this hood and its at match from looking at the pics. Right, it probably will fit a70- 71 barracuda also.
Anybody try to fix a corner like that's in bad shape like this one? understructure I think I can fix but never messed trying to fix a corner that's buggered up like that. Any ideas?
Thanks.
Post some measurements of it.....the angle of the pic might be making it longer than what it really is. I've had a few Plymouth E bodies and they are on the short side since they had a header panel in the front that's about 6" long. And fixing a corner is generally kinda hard. Depending on how bad it is, it might be easier to cut it off and weld on a good piece from a hood that's junk otherwise. The Plymouth E body did have the script in the leading left side part of the hood but don't know if other Plymouths had that too....
Yeah, that's what I was thinking. Best maybe to just cut it off and graft another corner from another hood onto it.
