2003 Ram 5.7 2500 237,000 miles.. Started as I had an intermittent miss, Then went into limp mode. Shut-off vehicle started back up and made it home had the small gauge lamp light up with the lightning bolt on right side of dash.. That went away after restart. Parked vehicle then a no crank condition with intermittent start stall. I chased everything and found it was the ground strap on the drivers side valve cover because it was chewed through by mice... I just bought the last NOS Valve cover ground strap in the US from any dealership as they are discontinued not supereceeded and GONE from everywhere on the net... Anyway my question is do I need to remove the entire valve cover to replace this strap? I believe I do and if so what should I buy to complete the job correctly?
