Will brake caliper clear sway bar
Bill76
12:43 AM
milwaukee
Looking to put wilwood disc brakes on front of 67 R/t
problem is wilwood teck does not know if they will clear front sway bar and he wasn't sure if they could be mounted to face rear of spindle.
Brakes in question part number 140-11020 11 inch rotor , 4 piston caliper
I really want to use wilwood because they look good and very well made and I can get a screaming deal at the roundly round shop that's 3 blocks from my home.
Will they clear the sway bar if mounted toward the front ? or can they be mounted toward the back of spindle ?
Thank you
Bill76
Hard to answer your question since I know nothing about you. I could make them fit if the car was in my shop but I don't know if you can make them fit. There are lots of ways to make it work, just depends on how big your tool box is and how thick your wallet is. I doubt that it will be a bolt on job.........
Are these the ones that fit the Mopar drum brake spindle? If so then you can rear mount them. Front mount they will probably hit the swaybar.
These are on drum brake spindles.
Sounds like you have never installed Wilwoods. Don't need a big tool box and yes, they are pretty much a bolt on job. Pretty easy really.
