Corner Balance Calculator.....
I assume you should do this with your weight in the drivers seat.
Also I didn't see a recommendation for drag racing. Start at 50/50 for a base line there, or a something else?
Good info either way!
Sure seems like tike this could be valuable if your application is optimizing left & right turns. I presume driver weight & all liquids must need to be included. My opinion. Drag racing setup is different from turning left & right.. See Dave Morgan "Door Slammers: The Chassis Book".
Got one of those books floating around here somewhere. Loaned it to a member many months ago and I guess he decided to keep it. Btw, your corner weights on a drag car will vary depending on your suspension setup.
