andyf
I see now! You need a drive shaft with a splined slip joint at the front, adapted to the correct u-joint. Should be no problem having a competent shop build one.
I don't think that will work. You can't have a u joint in the front and in the back with a spline in the middle. The driveshaft would flop around. Trucks use a bearing in the middle when they do it that way. The OP needs to source a different transmission.
