EngineerDoug
Hello all,
I am planning a stroker build for my 440 block and would appreciate some advice. I will be using the TrickFlow 240 heads on a 500 inch stroker. Cam will be a solid lifter with perhaps 0.520" to 0.550" valve lift. Spring pressures will be maybe 330lbs (open). I see that there are several choices for a complete rocker arm setup, and they vary widely in price.
This will be a street use engine, so I am interested in a rocker arm setup that will not break the bank. I don't want junk, but clearly this is not a high rpm race application either.
Your thoughts/experience? Thanks.
