- 12:49 AM
- Jun 12, 2012
- NZ - just short of the South Pole
Now you're just beingmaybe move it a millimeter
Oh man, beat it with a BFH!!Do the test that YY1 states with the front wheels off the ground. That will let you know if that valve needs centered.
Loosen the bolts but let them remain a little snug. They still have to seal the prongs under the block while at pressure. Use a hammer and wood block to tap it one direction along the axis of the steering gear. It will either get better on not turning (right direction to adjust) or worse. If worse tap the other direction.
Its fairly easy. Go in small movements
The alignment guy told me the gearbox was pulling, so I took his word for it. When I got it home, I jacked up the front end, started the car up & the wheel stays centered. Looks like I'm a victim of a shitty alignment.
Time to go elsewhere.
You called it right Mario.See post #8
[/QUOTE]Pete
My cars pulling to the right ever so slightly. Do you recall which way you had to move yours to correct it?
QUOTE="firiepete, post: 911524780, member: 15918"]Hello from Melbourne down under. I had the exact same problem after replacing the steering box. Took me a few goes to finally position the valve on top of the box right as kiwigtx has shown. Good luck. Stay safe in these terrible times.
Been there more than once!! That's when I decided to learn how to do my own alignments.....The alignment guy told me the gearbox was pulling, so I took his word for it. When I got it home, I jacked up the front end, started the car up & the wheel stays centered. Looks like I'm a victim of a shitty alignment.
I found out the hard way in the mid 70's lol and you can pull the coil wire and just turning the engine over with the starter will tell ya if you're close.....If you adjust that KEEP YOUR HANDS OFF THE WHEEL when you start the engine!
