gkent
Hot tanks generally used Caustic Soda because its ideal for removing paint, grease and gunk BUT since its a "base" its not effective removing rust. "acid" - which is at the other end of the scale, is ideal for removing rust BUT it has no effect on paint, grease and gunk.
So do your own test ... buy a bottle of Draino, mix it up and toss in a rusty part. At the same time toss a painted and greasy part in a mix of Muriatic acid. Days later you can pull the parts out and ... they'll look the same as when you put them in.
Now rinse them off and switch them around. Totally different results.
Hot tanks do not remove rust !!
