wheatdog
Bought a '64 Polara with 413 and pushbutton trans about 3 years ago. Pulled the engine and replaced with a hipo 512 stroker using a B block 400. Now that that's done I decided to take a look at some part numbers on the original engine which I thought was a turd cause it was running on about 6 cylinders when I got it (cam lobes were shot). The guy I bought it from said his father had the car for about 30 yrs and had done some performance work on it. So----I checked the casting nos on the cylinder heads and came up with 2406518-1. I looked on a mopar website that listed casting numbers and they said these heads are '64 426 Max Wedge heads with 2.08 in./1.88 ex. valves and 86cc chambers. Wow. Is this correct? If so, the resto maniacs may give me some $$$ for them right?
Is this the correct casting number for these heads and if so what are they worth in good condition?
