What are these solid rocker arms off of?
Hopefully this link will work from For A bodies. They look like my 63 max wedge head stands/“pedestals” but I have after market rockers. I found this pic and link:
Max Wedge Complete Rocker Assy with Push Rods
View attachment 932759 Hopefully this link will work from For A bodies. They look like my 63 max wedge head stands/“pedestals” but I have after market rockers. I found this pic and link:
The Max Wedge & Long Ram/Short Ram stuff looks allot like the Isky rockers except Mopar used friction type adjusters which pretty much suck & Isky used adjusters with lock nuts...
The rockers the O/P posted look more like Crane/Erson/late Isky which are actually relabelled Crane... Pictured below..
The problem as I see it, is the op posted pictures of the bottom of the rockers. All the distinguishing features are on the top of the rocker.
And those stands can absolutely be max wedge, the early four bolt valve cover versions.
Those stands are Max wedge Stage I for sure. Not sure when they changed over to cast in stands...maybe Stage III
in the op photos not in this life time & the photos in the a body only ad yes
We are talking about the aluminum stands correct? They were common on all big blocks up until 1964. Early Max Wedge used these with mechanical rockers and standard engines used stamped steel. Did I miss something here?
these are correct factory 62-63 max wedge rocker arm stands.
So your saying they are different because of the little tab on either side? We used to mill those off and custom shim each rocker. I have set of stands in the garage from a 413 Stage One . I have to take a look now.
you would be correct
Well I found the box of rockers and stands and you were right. I guess I remember milling the stands as replacements
I'm sure it was a pretty common thing to do & I wouldn't blame anybody for doing it.
