Maybe when you cleaned it you actually got crud in the idle passages.
They are small. You can try the old back out the idles screws quite a ways, then play with the throttle up and down.
Or remove the idle screws and try carb cleaner/air to blow them out.
Best way of course is to remove and disassemble again.
Sound like once the choke came off it would quit too lean.
Or maybe you do have more loading in gear than before.
Neutral or Park should be the same as always.
