- 8:18 PM
- Mar 10, 2010
- Hanover, Pennslyvania
It gets hot in that engine compartment. Could the distributor pickup get hot and fail and then cool down and be good?
That's one thing that can happen.
I like to get out and take off the air cleaner, give the throttle a pull and see if it gives a good squirt of gas. If it does, you've got gas.
Then I'll see if it has spark. Pull the coil wire and find a good place to lay it where you can see the end of it while cranking the engine. Of course you need to have the end at but not touching a bolt head or a bare spot on the manifold, and look for a good spark. Then you can go from there.
Your symptoms sounds like the pickup. If you have a ohms meter you could test it for continuity when it stops on you next time. If you have a spare you could swap it and see if it does it again next time you take it out.
Normally the ballast works or it doesn't. Having a ohms meter along can help check this too. Also helps with checking where you have voltage or not.
