Home made tools
Tony Tee
12:38 PM
ocala florida
Any creative people on a budget building their own tools instead of buying them or paying someone else to do it? Post some pictures. And help share some good ideas. First picture is a gizmo to remove axel studs studs without hammering them
Second picture. Torsion bar removal tool.
Third picture is a pitman arm removal tool
Fourth picture is a gas tank lock ring tool.
Been doing that my entire life but never thought to take pictures of them. All pretty much one and done just to finish the job.
Good on you.
Search for a thread on here called "Tools Explained". You'll enjoy it.
Crude but useful.. Zipped this together to spread exhaust pipes for header collectors. There was an Hpipe so all I had to do was get a half inch out of it for them to align. It did have a second angle iron welded to the other end. But it made it wasy to spread the pipes.
View attachment 940101 View attachment 940102 View attachment 940103 View attachment 940105
Here's two more
A intermediate shaft bushing driver.
And a upper ball joint socket.
Rest are for working on 1st Gen Cummins truck and motors....
For pulling injectors...
Holding the clutch fan pulley to break the nut loose on the clutch....
And for popping the rear push rod out of a Hydroboost braking system...any other way and you destroy the piston inside, don't ask how I know this. :(
When I put my dana 44 together I put the center in freezer over night
I should build one of those
Here is one I am building right now, 36" slip roller.
View attachment 943074 View attachment 943075 View attachment 943076
Definitely would like to see it when finished. I was thinking of building a 36" as well.
Definitely po
Ok, I will get some pictures when its done. I am in the process of painting it now but it isn't real warm so it takes some time for the paint to dry.
I will say this, my initial design was flawed, I did not include any bearings or bushings in the top or back rollers both of which are adjusted via bolts. without bearings or bushings the ends of the rollers would just dig into the ends and it would not turn. I ended up getting some bushings and had to remove ends I made and turn them down to 3/4" and reassemble them.
