63 fury radiator size
63fury500
2:36 AM
Beaver Dam, Wisconsin 53916
Looking for an aftermarket alminum radiator duall fan combo,does anyone have the measurements that fit a 63 and also what brand type come with a 3-4 row with fans,thanx in advance
I have a B cool radiator with all the hook-ups. Sorry no fans. I did not need them for the max wedge I was running. $200.00 plus shipping.
The one Im using is a B Cool as well. Quite a bit wider and mounts on the frame rails w/pins.
Also dual fans. Its a cross flow w/4 rows of tubes. Sorry no pic of the combo.
Tough fit if the motor is in the stock location. I could not find a dual fan setup that was shallow enough. I ended up i stalling a 26" downflow from cold case without modifying the 22" opening. The narrower top tank and straight mounting ears allowed enough space to install a short clutch fan. Cold case may have an electric fan option for you.
I don't have any measurements but I can get them later today. I thought these pics may give you an idea of how much room you have. I have an Afco rad I bought from Mancini and I use a back-up pusher electric fan that's on a toggle switch so I can turn it on if I am stuck in traffic. I will try to get in the garage and get measurements today. Ron
Thanx
22" O.E.M. with 4 core with factory shroud,all I had to do was decrease the fan spacer length by 1/2"
I'd ask the question of why you need the extra electric fans. High HP car? I had a 22" factory radiator with a custom shroud in our '64 Fury with a mild 440. It would run up over 200 degrees in the summer. I installed one from "Auto City Classics" and brought the temperature down 20 degrees at least. Also, no shroud, nor electric fans. I have a flex-fan on it now, but the original, factory fan will fit. This radiator is aluminum, bolts up to the original location, looks correct, and was cheap! I'll be buying another for our '63 Fury N/SS car soon.
700 hp car
Same company I mentioned above makes a package that uses this radiator with a dual-electric fan package. Their website sux, but the product is very good and fit perfectly.
did you have a link to that radiator,looked on the site didnt find anything
I looked into my notes and found this. I'd call first to confirm that the inlet/outlet are in the correct position for you. I ordered one with an incorrect, lower outlet first. Sold it to a friend that needed it, then re-ordered. I'm not sure which one this one is. When I called, they were very helpful.
Mopar Radiator 22" Cuda Challenger Charger Road Runner RT Superbee 1970-1972
352361712939
$229.00 USD
352361712939
$229.00 USD
thanx
