66 Dodge Coronet Reverse Light Switch Column Trigger
pat55ski
New Member
8:28 AM
Williamsville, NY
Reverse lights don't work on my 66 Dodge Coronet 440. Took the reverse back up light switch on the lower steering column and the switch trigger lever that is attached to the column fell to the floor. I've been on a mad hunt for this part. Does anyone know where I can find one? Appreciate the help.
3D printer have a good one to copy
In a 66 it's a metal pin in a 67 it's a plastic pin. I can see doing a 67 with a 3D printer, but I don't think you would have the strength in a 66 pin. I just found out the difference when I pulled one for a person here. It was a 67 plastic pin.
Having a 3D printer is great, but you will need a 3D cad drawing of the part in order to print it or anything else you would want to make.
