Bobby Sixkiller
Ok so an 8 3/4 with the sealed bearings. Does the piece inside the carrier. Between the spiders that pushes one axle into the other for the factory adjustment need to come out if the sealed axle bearings are used? I’m hearing a noise and probably need to pull it all out anyway. Just curious. Or should I go back to factory adjustable axle bearings ?
