70 B Body wiring protector?
A70Runner
3:24 PM
Mooresville NC
Hope I described it correctly...lol.
What holds this protector in? Is it welded or just
Seam Sealed in? I ask because mine went missing when the floor pans were done. Not even sure if I even need to worry about it.
If you weren't so far away I'd offer you half my set - I only need one side !!
A section of PVC pipe of a similar radius could be cut on a table saw and hinged to provide a similar conduit.
I had to take mine out in the drivers side to weld in a new floor pan. I used sheet metal screws to put it back down.
Are you sure ... 'cause the first reply says they weld in!
Dear stupid dummy,
This gives me, obviously not you additional confirmation that the information is likely correct.
From, I think I’m Sure
