- 3:54 AM
- Apr 13, 2012
- Granite Bay CA
I didn't want to hijack the Swedish guy's thread anymore so I started this thread.
I'm rebuilding the original engine in this car:
It is a 383 2 barrel. It is virgin bore with original pistons, steel crank, 727 trans and 3,23 gears. I have other ratios I can use including 3.55s and 3.91s. I put a 3.23 chunk in it just because I had it handy.
I will be using 1 7/8" headers, a Holley 750 vacuum secondary carb on either a Holley Street Dominator or an Edelbrock Performer RPM intake. At first I might get it running with a points distributor or a stock based electronic ignition.
I am looking to be at or below 9.5 to 1 since I am using iron heads with stock valve sizes. I have a set of '346 heads that had been rebuilt with new exhaust seats put in. I did some amateur porting to them and have them at the machine shop now for a 3 angle valve job.
I'm using these pistons by Speed Pro:
https://www.summitracing.com/parts/slp-l2315nf30
I am not building this engine strictly to race, I want reliability and adequate power since I'll primarily drive on the street. THis engine may not be the only engine that I use in the car. I may step up to a 440 or stroke this 383 sometime later on. I just want to get it running and have some fun with it. I may road race it . I'm not interested in building a track-only car though.
I have manual disc/drum brakes so idle vacuum isn't a concern.
I have several nice sets of stock rocker arms and shafts/pushrods so I am leaning toward a hydraulic flat tappet.
"PR Heads" mentioned something to the effect that the popular fast rate hydraulics are not suited for rpms over 6000 and my understanding is that the 383 needs to rev that high to make decent power. I respect his advice so I guess that to have some higher rpm capabilities in a hydraulic FT cam, I'd need something different than that. I ran the MP 280/474 in a stock piston 440 and it was a great performer but with the BS pricing of their cams now, I'm looking elsewhere.
I am not against a solid flat tappet even though the cost for rocker arms and pushrods adds several hundred to the cost of the build.
I am interested in camshaft suggestions as well as advice on piston rings. Cast iron? Moly ?
The Speed Pro uses a 5/64-5/64/3/16 ring pack.
Thanks!
Thanks!
