Floor pan wire tab question
Durandal25
2:44 PM
Texas
Team,
Silly question, but what do you call the tabs that screw to the floor pan that holds wire harness......the ones that run under the seats.....bendable....
I call them tabs too. Also, they were spot welded to the floor pans at the factory, not screwed down.
I had to remove my wire harness 'chases' when I redid my floorpans. To reinstall the chases and tabs to the new floor I drilled a hole thru the tabs and the floor and then plug welded them. :-)
I had to remove my wire harness 'chases' when I redid my floorpans. To reinstall the chases and tabs to the new floor I drilled a hole thru the tabs and the floor and then plug welded them. :)
....on my 67, they were screwed......but who makes them?
I haven't seen those reproduced. Same for the tabs under the hood that fold over to hold our wiring harnesses in place. As far as I know those tabs have to come from a donor car.
I can't speak for the 67 model year but in 64 my tabs on the floorpans and in the engine compartment were spot welded.
I haven't looked to see if they sell them separately, but one was included with the AMD floor I ordered.
I didn't get one with the half pan I ordered.....from AMD. I wonder If I call them.....
