A friends dad put a vertical shaft Briggs and the flying disc transmission from a Snapper riding lawn mower onto a go kart. He had it locked out of 4th and 5th because it would go too fast. Pretty cool because it had neutral and reverse.
....holy crap! Man, those suckers must have hauled ***....I got mine from my Uncle. They were on farm weed mowers. 3.5 horse from what I remember. The go cart guys would shave the heads and hop them up and get 15+ horse out of them on alcohol.
Took a 6 hp Tecumseh and stuck on a straight pipe (yeah, that's pretty much my MO), took out the choke blade and shaft and did a bit of cleaning up the ports and made sure the carb was matched and that little engine responded way more than I thought it wood!....holy crap! Man, those suckers must have hauled ***....
yep those Tecumseh'sTook a 6 hp Tecumseh and stuck on a straight pipe (yeah, that's pretty much my MO), took out the choke blade and shaft and did a bit of cleaning up the ports and made sure the carb was matched and that little engine responded way more than I thought it wood!
I think they were rototiller engines org.
I think they were slightly taller too, longer stroke (?)
take the gov. off, 2 times the power "Wahoo"
something like 5-7hp stock IIRC,
also they were a lot heavier IIRC big Iron crank cases,
compared to the 2hp to 3.5hp B&S's
(my stepdad Bob had a few of them laying around)
some had slotted holes, same bolt pattern
(I think as the smaller B&S engines)
they were the go engines
to replace for more power on my Taco 22 or 44 mini-bikes
& no name Go-carts too
I had kicked rods out the front side of every
Briggs & Stratton engine I had
2 stroke McCullough
I had a home brew/garage built (stepdad Bob was a pipefitter)
shifter go-cart with 2 Mac 101's
it was flat out fast & dangerous, like 90mph dangerous
& Rotax (pricy fuckers)
my stepdad Bob was a small engine guy
I never got into them as much
& I really liked Motorcycle, MX dirt-bikes
or big 1 lungers 2 strokes/desert bikes
3 wheelers & then Quads
& then at about 14-15 or so, I got into cars/dunebuggies,
left that small engine (especially 4 strokes) stuff behind
still played with the 2 strokes, Motorcycles & Quads
