70chall440
- 11:27 AM
- Feb 11, 2018
- Yelm, Washington
I need a sanity check here because I don't do these all that often; the story is that I am working on a 69 Belvedere wagon and as a part of my overall effort I had to remove the axles and swap out the 3rd member. I ended up putting new studs in both axles and new seals into the rearend housing. I reinstalled the axles and went to adjust the end ply by the manual, however with the adjuster turned all the way out, there is no movement in the axles left and right. They will rotate and are not bound up, but also there isn't any movement left or right.
Supposedly new bearings were installed some time ago along with new seals, however the seals were not installed correctly and the left one was running on the bearing retainer which makes me believe that the bearings and/or retainers are not seated correctly, thus having eliminated the end play but again, I don't do this enough to say for sure.
I would appreciate any thoughts or advice.
