Hemirunner
Anyone know of a source for the pins for the connectors for both the ignition switch and turn signal switches? I’m assuming that since you can buy a reproduction harness that the connectors are available separately??
Have you tried one of the reproduction manufacturers?Anyone know of a source for the pins for the connectors for both the ignition switch and turn signal switches? I’m assuming that since you can buy a reproduction harness that the connectors are available separately??
I’m going to call M&H today. I’m not aware of anyone else in that business.Have you tried one of the reproduction manufacturers?
It’s a 70. I’m building a custom harness and I didn’t want to cut and splice if I didn’t have to. I can reuse my plastic housing if I could source the pins.Year?
If 70 and later, terminals are Molex and those are available, but plastic insulators for ign and turning switches are not available separately. Never have seen them at least from the repro/replacement market ( and I use to be over this topic with regularity ). Ign switch female end was available NOS some years ago from some Mopar NOS parts dealer thought, but can't recall which it was.
are these what you are needing?View attachment 966831
I ordered the molex pins in .062 and .093 as there are two sizes in the ignition switch connector. You have to leave a certain amount of that “chain” material on each side of the pin as it keeps the pin from pulling through the connector. Learned that one the hard way lol.
