radiator question
Beekeeper
It’s a disease without a cure!
5:44 AM
Rogersville,TN.
would a 3 row 22” radiator be big enough
to cool a 472 hemi?
would like to go with original style radiator
and no AC does have power steering and 4 speed
We need some more info.
what fan?
Shroud?
what water pump?
What coolant?
What temp thermostat?
How much horsepower does it make?
What kind of driving?
Have a hood scoop? Open or sealed?
What oil weight? (Thin oil cools better)
Fuel mixture checked with O2 sensors or EGT?
The 4 speed helps some
what fan?
Shroud?
what water pump?
What coolant?
I agree
1965 Belvedere 1 472 Hemi crossram 180 stat original 22 inch Radiator with shroud stock fan and clutch 180 cruise 190 in traffic 200 the max in 95 degree stop and go.
what fan?
Shroud?
what water pump?
What coolant?
none of the above this is a new build just wanted some info before i go down this path. My 69 bee has a 22” opening and dont want to change with all the paint work being done already. HP 600 to 650 street driven
six pack hood and 10w-30 oil.
I've used the wider radiator with the small cowl opening. Not ideal but can get the job done, may need to experiment with the fans & a shroud sure helps.
Just get the cold case setup with electric fan and should combo. You’ll never go back.
