Ironbuilt
Hopefully not these!!!What brand of jack stands?
BTW, Idiots use cinder blocks.![]()
https://www.harborfreight.com/3-ton-aluminum-jack-stands-91760.html
LMAO! I actually pictured a buddy of his stripping the thing apart and wondered off drinking beer, it didn't even occur to me he did the teardown LolNext tine the Idiot (you) takes something apart, take plenty of pictures and document everything. Also label ALL parts, nuts and bolts, it makes life easier when it comes time for the install.
I give you a lot of credit, IT NEVER HURTS TO ASK!!!
Thank you for this! How many Mopars have you owned? My first car was a '72 Charger (318), second was a '69 Satellite, had two '70 Super Bees, another '69 Satellite, and now my '73 Road Runner... I THINK that's all I had... Had newer cars, but always had an old Mopar for some reason... I guess I could never let it go...DUDE ok I'm fired... I totally forgot this is a later b body and the strut rod mounts on the lca and doesn't go through it. here's some pics of my old charger @pdiz
What are these "jack stands" of which you speak?What brand of jack stands?
too many to count lol , that plate painted red above, has two adjusting stands poking up through it, those have to be in position before the plate is bolted down. that's what your uca attaches to and thats how you adjust your camber/casterThank you for this! How many Mopars have you owned? My first car was a '72 Charger (318), second was a '69 Satellite, had two '70 Super Bees, another '69 Satellite, and now my '73 Road Runner... I THINK that's all I had... Had newer cars, but always had an old Mopar for some reason... I guess I could never let it go...![]()
I almost hit the red X on this one....everyone literally IS as smart as me and (I pray) smarter.
OP, don't be so hard on yourself, man...
Don't be so rough on yourself. Take lots of pictures, notes, and have a service manual.So some "idiot" removed every part of my entire front suspension a "couple" years ago (engine/trans/K-member not removed), and now he can't figure out in what order to re-assemble.
The car is a '73 Road Runner. Frontend is on jack stands.
This "idiot" sandblasted and painted and/or RPM (Rust Prevention Magic) every piece that could rust.
This "idiot" figured out how to remove/reinstall the bushings in place for the LCA arm using a Harbor Freight press, and even figured out how to weld a strengthening plate to them.
This "idiot" has Firm Feel's tubular UCA.
This "idiot" even removed and reinstalled the rear torsion-bar cross-member and installed solid bushings after sandblasting and painting that piece. "Idiot" even figured out how to install solid bushings on the K-frame, etc.
This "idiot" is armed with all new MOOG suspension bushings, ready-to-go LCAs, ready-to-go spindles, but is confused about what can be assembled/torqued off the car, what can be assembled but not torqued until the car is on the ground, etc. What to do first? Second? Third?
"Idiot" does have a shop manual, full tools, including 250 ft. lb. torque wrenches and compressor and pneumatic tools and even Mopar ball joint sockets, etc.
But now "idiot" is staring at a bunch of parts off the car and doesn't know in what order he should proceed...
So far, he's done this:
Installed the floating torsion-bar rear crossmember using solid bushings, torqued to “only” 35 ft. lbs. at the recommendation of Firm Feel (they aren’t Firm Feel’s parts, but they are from a defunct company called “solidbushings.com").
He's looking at this:
spindles, knuckle arm, caliper bracket, torsion bars, full MOOG bushings, etc.… torque now, or just mate it all up and torque it later? What should go on first, though? Tie rod ends? Pitman arm? UCA? LCA? Spindle?
"Idiot" would prefer someone that can explain to him like he's three, and if it's very detailed, can even thank them with beer/PayPal/etc.
"Idiot" can look up torque specs from the factory manual, and even procedures, but it's difficult when EVERYTHING is disassembled due to the "modular" way the factory manual is written.
"Idiot" is just looking for something like:
CAR OFF GROUND, so…
(EXAMPLE ONLY
1. Install strut rods to car at this point… DON’T TORQUE UNTIL CAR ON GROUND ** OR** Install strut rods to LCA and torque to spec, THEN install strut rod to car, but don’t TORQUE until car on ground
2. Install spindle knuckle and torque down BEFORE putting on car
That kind of stuff… And is looking for where to begin...
"Idiot" may be me, but don't tell anyone.
