Cheetah SCS Shifter
Frankb
2:57 PM
Tucson
I have a console in my 68 Charger. I want to remove the stock trans linkage and shifter and use a Cheetah SCS unit. Can the Cheetah be used with the factory console or will the console have to be removed? Thanks
Frank
Frank
Its been years, since i ran one in my cuda, but then they came in a black plastic casing, with a specific gate face plate. The entire assembly would need to be intact. It needs to be secured to the trans tunnel. Though my info may be outdated.
I am not in any way familiar with the console in a charger, so i cant answer your question. What you need is the dimension from the bottom of the gate plate on the shifter, to the mount surface, verses the height of your console.
I have seen that shifter used in factory consoles, but i dont remember whose.
The shifter itself is bulletproof, just not driver mistake proof. I used one in my bracket car and occasionally pulled from first to third (rmvb). So, i changed to a B&M ratchet, and changed the top plate on the cheetah to use with a powerglide/brake. Bulletproof, and idiot proof in that application.
The black plastic housing was an option, basically to enclose and dress up the shifter, but also the could include a bunch of quality switches. That is the one i used, so all switches were near to hand.
