Landon
1969 Coronet. Does anyone have a clear answer on how to wire in my MSD6A? I have the car running and driving, but just feel like there is a better way of doing it. I have my coil connected to the MSD box, and the MSD box heavy red & black fed from the battery correctly.
The small red from the distributor & the small red from the MSD box are supposed to both be tied into 12v ignition per MSD diagram, but I had to tie them into the line side of the voltage regulator with the brown (start) wire and the dark blue (run) wire. Is this correct? Should all 3 be connected to the line side of the voltage regulator? I do not have any wires going to my 2 pole ballast resistor...
