Fuel type
gaspar sosa
2:31 AM
Las vegas, NV
Hello, I got my car running and I have a question about what type of fuel to use and since is an old car should I use some kind of additive
It depends on which engine you have and what has been done to it.
Here we have Ezero with no ethanol but it is only 89 octane. I can’t run on that octane level so I use VP 110, lots of octane and lead like God intended.
I run 92 octane pump gas with 10% ethanol (I have no other choice). No problems with it.
Thank you all for the reply, I have a 383 magnum original and I know that lead was used in the 60'.
I use 93 octane 10% ethanol gas. No troubles. I do have hardened valve seats. I’ve also run tens of thousands of miles without hardened valve seats without trouble too. Nothing in the car is modern.
Thank you.
